Zum Hauptinhalt wechseln
Lenovo ThinkPad W540 Display Replacement
Was du brauchst
  1. Lenovo ThinkPad W540 Display Replacement, Display: Schritt 1, Bild 1 von 2 Lenovo ThinkPad W540 Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad W540 Display Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad W540 Display Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: Schritt 4, Bild 1 von 1
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kevin Dang
333 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 89
