Zum Hauptinhalt wechseln
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Was du brauchst
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): Schritt 1, Bild 1 von 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): Schritt 1, Bild 2 von 2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 2, Bild 2 von 2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 3 von 3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 4, Bild 1 von 1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Abschluss
Isaac
109 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Mitglied von UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 75
