Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: Schritt 4, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: Schritt 5, Bild 2 von 2
    • Pick up the fan and heat sink and carefully and remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team 1-3, Saknee Fall 2021 Mitglied von Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 63
Insgesamt: 1,895
