Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: Schritt 6, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 7, Bild 1 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 7, Bild 2 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 7, Bild 3 von 3
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: Schritt 8, Bild 3 von 3
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
Abschluss
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team 1-3, Saknee Fall 2021 Mitglied von Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 793
