Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Speakers: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Speakers: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    Kaufen
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Battery: Schritt 7, Bild 1 von 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Fan: Schritt 10, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Fan: Schritt 10, Bild 2 von 2
    Kaufen
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 11, Bild 1 von 1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 12, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
  13. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Mother Board: Schritt 13, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove all 16 of the 6 mm screws connecting the motherboard to the computer.
  14. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 14, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Using the nylon spudger, disconnect the grey and black wires.
    • Using the nylon spudger, gently disconnect the pink tab from the motherboard.
  15. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the black tape with your fingers.
    • Do not remove the sticky residue from the back of the section.
  16. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 16, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 16, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 16, Bild 3 von 3
    • Lift the Black flap using a plastic spudger.
    • Pull out the ribbon cable with the black tab.
  17. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the purple tab by gently pulling it out.
  18. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 18, Bild 1 von 1
    • Remove the blue tab by gently pulling it out.
  19. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 19, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 19, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 19, Bild 3 von 3
    • Gently lift up on the sides with your hands and remove the motherboard.
  20. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Keyboard: Schritt 20, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement, Keyboard: Schritt 20, Bild 2 von 2
    • Lift the black flap with the plastic spudger.
  21. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 21, Bild 1 von 1
    • Use the spudger to gently pry up the ribbon cable.
  22. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 22, Bild 1 von 1
    • Use the spudger to disconnect the ribbon cable.
  23. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 23, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 23, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the three 2.8 mm screws holding down this metal plate.
    • Repeat the same process with the identical metal plate on the opposite side.
  24. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 24, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 24, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two 5.4 mm screws connecting the hinge mount to the base.
    • Repeat on the opposite hinge mount.
  25. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 25, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 25, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 25, Bild 3 von 3
    • Open the laptop hinge by pulling the screen away from the keyboard.
    • Lift the keyboard up and off the hinge brackets.
  26. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 26, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 26, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 26, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 3.2 mm screws securing the metal bar on the right side.
    • Repeat with the identical bar on the left.
  27. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 27, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the two 2.5 mm screws on the metal plate in the center of the keyboard.
  28. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 28, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 28, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 28, Bild 3 von 3
    • Carefully pull back on the black tab to remove the ribbon cable from the back of the keyboard.
  29. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 29, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 29, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 29, Bild 3 von 3
    • Use the plastic spudger to pry up the black plastic sheet on the back of the keyboard.
    • Gently pull the sticky edges of the plastic sheet with your hands and a spudger.
    • Lift and carefully remove the plastic sheet.
  30. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 30, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 30, Bild 2 von 2
    • Remove all the 2 mm screws from the back of the keyboard using a Phillips #000 screwdriver.
  31. Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 31, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Keyboard Replacement: Schritt 31, Bild 2 von 2
    • Gently lift the keyboard out of the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thank You Mate !
Rajesh Mohan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 73
Insgesamt: 2,670
