Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Speakers: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Speakers: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/Angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 5, Bild 2 von 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 6, Bild 2 von 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Battery: Schritt 7, Bild 1 von 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 9, Bild 1 von 1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Fan: Schritt 10, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Fan: Schritt 10, Bild 2 von 2
    Kaufen
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 11, Bild 1 von 1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 12, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 12, Bild 2 von 2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
  13. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Mother Board: Schritt 13, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove all 16 of the 6 mm screws connecting the motherboard to the computer.
  14. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 14, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 14, Bild 2 von 2
    • Using the nylon spudger, disconnect the grey and black wires.
    • Using the nylon spudger, gently disconnect the pink tab from the motherboard.
  15. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the black tape with your fingers.
    • Do not remove the sticky residue from the back of the section.
  16. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 16, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 16, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 16, Bild 3 von 3
    • Lift the Black flap using a plastic spudger.
    • Pull out the ribbon cable with the black tab.
  17. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 17, Bild 1 von 1
    • Remove the purple tab by gently pulling it out.
  18. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 18, Bild 1 von 1
    • Remove the blue tab by gently pulling it out.
  19. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 19, Bild 1 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 19, Bild 2 von 3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: Schritt 19, Bild 3 von 3
    • Gently lift up on the sides with your hands and remove the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
So searching for motherboards, there are several different "gens". Can any of these be used to replace one? Or is it necessary to replace with the same gen?
Bryant Hayward - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 38
Insgesamt: 1,523
