Zum Hauptinhalt wechseln
Lenovo ThinkPad X140e Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: Schritt 2, Bild 1 von 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X140e Battery Replacement: Schritt 3, Bild 2 von 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Abschluss
Dylan Halland
318 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-5, Livingston Fall 2016 Mitglied von Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 963
