Einleitung
Has your computer performance diminished? Try replacing the RAM card.
Was du brauchst
Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
The RAM is hidden behind the black piece of plastic. Pull the plastic back.
The RAM is held in place by two metal pieces on both sides.
Use the spudger to push off both metal pieces to release the RAM.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
