Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 3, Bild 2 von 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 4, Bild 2 von 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: Schritt 5, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 6, Bild 2 von 2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: Schritt 7, Bild 2 von 2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 852
