Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: Schritt 1, Bild 1 von 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 3, Bild 2 von 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 5, Bild 3 von 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: Schritt 7, Bild 1 von 1
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 8, Bild 1 von 1
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 9, Bild 2 von 2
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: Schritt 10, Bild 1 von 1
    • Using tweezers, remove the fingerprint reader from the inset.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 299
