Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 370 Screen Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 4, Bild 1 von 1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 370 Screen Replacement: Schritt 5, Bild 3 von 3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 86
Insgesamt: 2,137
