Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad Yoga Keyboard Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad Yoga Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: Schritt 3, Bild 3 von 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: Schritt 4, Bild 1 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: Schritt 4, Bild 2 von 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: Schritt 4, Bild 3 von 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the keyboard from the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 46
Letzte 30 Tage: 254
Insgesamt: 6,963
