Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga Screen Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad Yoga Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad Yoga Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Screen Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad Yoga Screen Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad Yoga Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Screen Replacement, Screen: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Yoga Screen Replacement, Screen: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Yoga Screen Replacement, Screen: Schritt 3, Bild 3 von 3
    • Remove two screws under the plastic covers on the front of the screen using a Phillips #0 screwdriver.
    • Pry the plastic cover off with a spudger.
    • Remove the two screws from underneath the cover using a Phillips #0 screwdriver.
    • Detach the screen connector from the rest of the laptop.
  4. Lenovo ThinkPad Yoga Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the screen from the rest of the laptop.
Abschluss
Michael Nessralla
171 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 123
Insgesamt: 2,132
