Zum Hauptinhalt wechseln
Lenovo Yoga 710-15IKB Fan Replacement
Was du brauchst
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 2, Bild 1 von 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 6, Bild 1 von 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: Schritt 7, Bild 1 von 1
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
University of Maine, Team S1-G5, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 2,140
