Einleitung
This guide will show you how to replace your trackpad if it is broken or defective.
Was du brauchst
Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
Pull tab until it disconnects from the trackpad. Be gentle - you do not want to damage any part of the tab.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
