Zum Hauptinhalt wechseln
Lenovo Yoga 720-15IKB Wireless Adapter Replacement
Was du brauchst
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: Schritt 2, Bild 1 von 2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: Schritt 2, Bild 2 von 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: Schritt 3, Bild 1 von 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: Schritt 3, Bild 2 von 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: Schritt 3, Bild 3 von 3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: Schritt 4, Bild 1 von 1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: Schritt 5, Bild 1 von 1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
Abschluss
Cal Poly, Team S19-G3, White Winter 2020 Mitglied von Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 735
