Einleitung
Use this guide as a reference when removing the back case on the Lenovo Yoga 730-13IKB laptop (models beginning with “81CT”).
Removing the back case exposes the laptop’s internals and is a prerequisite step for replacing or repairing most components. Always power off the laptop before working on any internal components.
Was du brauchst
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
