Einleitung
If you need to replace the Wi-Fi card in your Lenovo Yoga 910-13IKB follow this guide.
Was du brauchst
Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
Remove the back panel from the device exposing the components.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
Lift the battery out.
Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
Detach the black wire by applying gentle pressure.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
