Zum Hauptinhalt wechseln
Mac Pro First Generation GPU Replacement
  1. Mac Pro First Generation GPU Replacement, Case Panel: Schritt 1, Bild 1 von 1
    • Lift the lever to unlock the case.
  2. Mac Pro First Generation GPU Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
  3. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): Schritt 3, Bild 1 von 1
    • Locate the graphics card in the open panel side of your Mac Pro.
  4. Mac Pro First Generation GPU Replacement: Schritt 4, Bild 1 von 3 Mac Pro First Generation GPU Replacement: Schritt 4, Bild 2 von 3 Mac Pro First Generation GPU Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
    • Remove the slide lock.
  5. Mac Pro First Generation GPU Replacement: Schritt 5, Bild 1 von 3 Mac Pro First Generation GPU Replacement: Schritt 5, Bild 2 von 3 Mac Pro First Generation GPU Replacement: Schritt 5, Bild 3 von 3
    • Push up on the clip directly behind the graphics card to release it from its slot.
    • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
    • Handle the card only by its edges. Don't touch any exposed components or connectors.
Abschluss
23 weitere Personen haben diese Anleitung absolviert.
Andrew Kim
1.263 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-24, Maness Fall 2014 Mitglied von Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Mitglieder
19 Anleitungen geschrieben
8 Kommentare zur Anleitung
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - Antwort Teilen
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - Antwort Teilen
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - Teilen
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - Antwort Teilen
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 53
Insgesamt: 23,545
