Zum Hauptinhalt wechseln
Mac Pro First Generation Optical Drive Replacement
Was du brauchst
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: Schritt 3, Bild 1 von 3 Mac Pro First Generation Optical Drive Replacement: Schritt 3, Bild 2 von 3 Mac Pro First Generation Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: Schritt 5, Bild 1 von 2 Mac Pro First Generation Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: Schritt 6, Bild 1 von 2 Mac Pro First Generation Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Firmly grasp the optical drive and pull it out of its enclosure.
Abschluss
21 weitere Nutzer:innen haben diese Anleitung absolviert.
Derek Chan
1.416 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-24, Maness Fall 2014 Mitglied von Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Mitglieder
13 Anleitungen geschrieben
10 Kommentare
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Antwort
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Antwort
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Antwort
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 68
Insgesamt: 16,752
