Zum Hauptinhalt wechseln
MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement
Was du brauchst
  1. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement, RAM Shield: Schritt 2, Bild 1 von 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 3, Bild 1 von 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement, Upper Case: Schritt 4, Bild 1 von 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 5, Bild 1 von 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 7, Bild 1 von 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 8, Bild 1 von 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 9, Bild 1 von 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement, Left Ambient Light Sensor: Schritt 11, Bild 1 von 1
    • Disconnect the left ambient light sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 12, Bild 1 von 1
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 13, Bild 1 von 1
    • Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
    • Lift the clear plastic shield off the left ambient light sensor.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor Replacement: Schritt 14, Bild 1 von 1
    • Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
    • Lift the left ambient light sensor board out of the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 8,340
