Einleitung
Diese Anleitung zeigt dir, wie du die Batterie deines Microsoft Band 2 wechselst. (Bekanntes Problem beim Band 2)
Was du brauchst
Nutze einen T3 Torx Schraubendreher, um die 4 Schrauben in den Ecken der Metallplatte zu entfernen.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
20 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
14 Kommentare
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
