Zum Hauptinhalt wechseln
Nabi 2 Screen Replacement
Was du brauchst
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 1 von 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 2 von 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 3 von 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2  Screen Replacement: Schritt 2, Bild 1 von 2 Nabi 2  Screen Replacement: Schritt 2, Bild 2 von 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2  Screen Replacement: Schritt 3, Bild 1 von 3 Nabi 2  Screen Replacement: Schritt 3, Bild 2 von 3 Nabi 2  Screen Replacement: Schritt 3, Bild 3 von 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2  Screen Replacement: Schritt 5, Bild 1 von 3 Nabi 2  Screen Replacement: Schritt 5, Bild 2 von 3 Nabi 2  Screen Replacement: Schritt 5, Bild 3 von 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Michelle
851 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 4-3, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Mitglieder
14 Anleitungen geschrieben
3 Kommentare
Simple steps but very practical
myjamro - Antwort
Is the LCD glued to the front glass/digitizer?
Brent Huff - Antwort
It Worked Thank U So Much!!!
Sharon Thrash - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 7,850
