Zum Hauptinhalt wechseln
Nabi 2 Motherboard Replacement
Was du brauchst
  1. Nabi 2 Motherboard Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 1 von 3 Nabi 2 Motherboard Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 2 von 3 Nabi 2 Motherboard Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 3 von 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Motherboard Replacement: Schritt 2, Bild 1 von 2 Nabi 2 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Motherboard Replacement: Schritt 3, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 3, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Motherboard Replacement, Screen: Schritt 4, Bild 1 von 3 Nabi 2 Motherboard Replacement, Screen: Schritt 4, Bild 2 von 3 Nabi 2 Motherboard Replacement, Screen: Schritt 4, Bild 3 von 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Motherboard Replacement: Schritt 5, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 5, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Motherboard Replacement, Battery: Schritt 6, Bild 1 von 3 Nabi 2 Motherboard Replacement, Battery: Schritt 6, Bild 2 von 3 Nabi 2 Motherboard Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Motherboard Replacement: Schritt 7, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 7, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Motherboard Replacement, Internal Speakers: Schritt 8, Bild 1 von 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Motherboard Replacement: Schritt 9, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 9, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 2 Nabi 2 Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Motherboard Replacement: Schritt 12, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 12, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Motherboard Replacement: Schritt 13, Bild 1 von 3 Nabi 2 Motherboard Replacement: Schritt 13, Bild 2 von 3 Nabi 2 Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the motherboard by lifting from the area indicated
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Michelle
851 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 4-3, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 1,131
