Zum Hauptinhalt wechseln
Neato XV-21 Battery Replacement/Removal
Was du brauchst
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: Schritt 1, Bild 1 von 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: Schritt 2, Bild 1 von 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: Schritt 3, Bild 1 von 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: Schritt 4, Bild 1 von 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 60
Insgesamt: 1,141
