Zum Hauptinhalt wechseln
Nexus 10 Battery Replacement
Was du brauchst
  1. Nexus 10 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Nexus 10 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Nexus 10 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Battery Replacement: Schritt 3, Bild 1 von 3 Nexus 10 Battery Replacement: Schritt 3, Bild 2 von 3 Nexus 10 Battery Replacement: Schritt 3, Bild 3 von 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Battery Replacement: Schritt 4, Bild 1 von 3 Nexus 10 Battery Replacement: Schritt 4, Bild 2 von 3 Nexus 10 Battery Replacement: Schritt 4, Bild 3 von 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Battery Replacement: Schritt 6, Bild 1 von 2 Nexus 10 Battery Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
Abschluss
63 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 34-18, Maness Spring 2016 Mitglied von Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Mitglieder
5 Anleitungen geschrieben
20 Kommentare zur Anleitung
that worked! watch connectors,though!
Dan Hestad - Antwort
I am not never before doing something like this before, but now i do this battery replacement and it worked very well. Maybe there could be more text describing steps 4 and 6 those were parts were me as complete novice had most difficult to understand at first. Step 4 you should say that you need to open that small lever-thing what locks ribboncables in its place (picture here is accurate, but i did not understand it at first). And step 6 disconnecting actual battery cable were more simple than i first thought, just lifting it upwards and then its basically free already just pull it away. Same connecting new battery cable back is same kind simple, just push it back there but better to do it first time right since that connector loosens easily i think.
Sami Pesonen - Antwort
I would agree with above comment about the ribbon cable levers. I was able to get them out easily but it was not until I understood how they worked that I successfully was able to get the ribbon cables reconnected.
drewcifer - Antwort
After the replacement there is the maximum charge 42%.
Anybody dies know anything about this Problem?
mlueb - Antwort
The back cover is one tough motherFer. The hardest is get to the pins behind the both speakers and in the curved corners. But the overall design is so cool
Constantine Tolstov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 55
Letzte 30 Tage: 128
Insgesamt: 39,142
