Zum Hauptinhalt wechseln
Nexus 4 Display Assembly Replacement
Was du brauchst
  1. Nexus 4 Display Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nexus 4 Display Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    SIM Card Eject Tool
    $2.99
    Kaufen
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    T5 Torx Screwdriver
    $5.49
    Kaufen
  3. Nexus 4 Display Assembly Replacement: Schritt 3, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 3, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 3, Bild 3 von 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Display Assembly Replacement, Battery: Schritt 4, Bild 1 von 2 Nexus 4 Display Assembly Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Display Assembly Replacement, Battery removal: Schritt 5, Bild 1 von 2 Nexus 4 Display Assembly Replacement, Battery removal: Schritt 5, Bild 2 von 2
    Plastic Cards
    $2.99
    Kaufen
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Display Assembly Replacement, Plastic Midframe: Schritt 6, Bild 1 von 3 Nexus 4 Display Assembly Replacement, Plastic Midframe: Schritt 6, Bild 2 von 3 Nexus 4 Display Assembly Replacement, Plastic Midframe: Schritt 6, Bild 3 von 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
  7. Nexus 4 Display Assembly Replacement, Speaker: Schritt 7, Bild 1 von 2 Nexus 4 Display Assembly Replacement, Speaker: Schritt 7, Bild 2 von 2
    • Remove the two 4.8 mm screws that hold the speaker enclosure together using the Phillips 00 screwdriver.
  8. Nexus 4 Display Assembly Replacement: Schritt 8, Bild 1 von 2 Nexus 4 Display Assembly Replacement: Schritt 8, Bild 2 von 2
    • Gently pry the speaker up and away from the back of the phone using a plastic opening tool, and lift it out of the phone.
  9. Nexus 4 Display Assembly Replacement, Audio Jack: Schritt 9, Bild 1 von 3 Nexus 4 Display Assembly Replacement, Audio Jack: Schritt 9, Bild 2 von 3 Nexus 4 Display Assembly Replacement, Audio Jack: Schritt 9, Bild 3 von 3
    • Using a spudger, pop off the gray connector on the top right of the motherboard.
  10. Nexus 4 Display Assembly Replacement: Schritt 10, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 10, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 10, Bild 3 von 3
    • Gently lift the audio jack upwards and to the left to remove it from the motherboard.
  11. Nexus 4 Display Assembly Replacement: Schritt 11, Bild 1 von 2 Nexus 4 Display Assembly Replacement: Schritt 11, Bild 2 von 2
    • The audio port will likely lift out together with the ambient light sensor rubber cap.
    • Remove the cap from the old part and move it to the new one. Ensure the cap stays in place when installing the new audio port into the phone.
  12. Nexus 4 Display Assembly Replacement, Camera: Schritt 12, Bild 1 von 3 Nexus 4 Display Assembly Replacement, Camera: Schritt 12, Bild 2 von 3 Nexus 4 Display Assembly Replacement, Camera: Schritt 12, Bild 3 von 3
    • Gently pry the metal tab up using a spudger, and lift up the disconnected black flap.
  13. Nexus 4 Display Assembly Replacement: Schritt 13, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 13, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 13, Bild 3 von 3
    • With a spudger, carefully pry up the black tab connecting the camera to the motherboard.
    • Lift up the camera from the socket.
  14. Nexus 4 Display Assembly Replacement, Motherboard: Schritt 14, Bild 1 von 3 Nexus 4 Display Assembly Replacement, Motherboard: Schritt 14, Bild 2 von 3 Nexus 4 Display Assembly Replacement, Motherboard: Schritt 14, Bild 3 von 3
    • Remove the Sim Card and the Sim Card metal tray.
  15. Nexus 4 Display Assembly Replacement: Schritt 15, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 15, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 15, Bild 3 von 3
    • Remove the white antenna interconnect cable that attaches the motherboard to the bottom right-hand corner of phone by pulling on it gently.
  16. Nexus 4 Display Assembly Replacement: Schritt 16, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 16, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 16, Bild 3 von 3
    • Remove the tab located in the bottom right-hand corner of the motherboard attaching the motherboard to the front display assembly using a spudger.
  17. Nexus 4 Display Assembly Replacement: Schritt 17, Bild 1 von 2 Nexus 4 Display Assembly Replacement: Schritt 17, Bild 2 von 2
    • Remove the last tab connecting the motherboard to the front display assembly located in the upper right-hand corner of the motherboard using a spudger.
    • Once this tab is removed, the flap will be free and will spring away from the motherboard.
  18. Nexus 4 Display Assembly Replacement: Schritt 18, Bild 1 von 3 Nexus 4 Display Assembly Replacement: Schritt 18, Bild 2 von 3 Nexus 4 Display Assembly Replacement: Schritt 18, Bild 3 von 3
    • Using a spudger, gently lift up the motherboard from the front display assembly.
    • Carefully remove the motherboard using your hands.
  19. Nexus 4 Display Assembly Replacement, Display Assembly: Schritt 19, Bild 1 von 3 Nexus 4 Display Assembly Replacement, Display Assembly: Schritt 19, Bild 2 von 3 Nexus 4 Display Assembly Replacement, Display Assembly: Schritt 19, Bild 3 von 3
    • Grasp the daughterboard with tweezers.
    • Gently pull upwards to slide the connector out of the charging port housing.
    • Remove the daughterboard from the display assembly.
  20. Nexus 4 Display Assembly Replacement: Schritt 20, Bild 1 von 1
    • Remove the power and volume button switches from the display assembly.
    • Compare your old display assembly to your replacement part and verify that they match. If there are any small components missing from the replacement display, transfer them over from you old display.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
Julia List
5.604 Reputation
7 Anleitungen geschrieben
3 Kommentare
Great post. I just replaced the Display assembly of a Nexus 4 using this guide now.
Jeswin Simon - Antwort
Many thanks!
Oli - Antwort
Replaced the screen and battery. Did tear up the edges of the back a bit, but it's going in a case anyway.
aSquirl - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 5,715
