Zum Hauptinhalt wechseln
Nintendo DSi XL Touchscreen Replacement
Was du brauchst
  1. Nintendo DSi XL Touchscreen Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Touchscreen Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Touchscreen Replacement, Lower Case: Schritt 3, Bild 1 von 3 Nintendo DSi XL Touchscreen Replacement, Lower Case: Schritt 3, Bild 2 von 3 Nintendo DSi XL Touchscreen Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Touchscreen Replacement: Schritt 4, Bild 1 von 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Touchscreen Replacement: Schritt 5, Bild 1 von 3 Nintendo DSi XL Touchscreen Replacement: Schritt 5, Bild 2 von 3 Nintendo DSi XL Touchscreen Replacement: Schritt 5, Bild 3 von 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Touchscreen Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 6, Bild 2 von 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Touchscreen Replacement: Schritt 7, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Touchscreen Replacement, Wi-Fi Board: Schritt 8, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement, Wi-Fi Board: Schritt 8, Bild 2 von 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Touchscreen Replacement: Schritt 9, Bild 1 von 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Nintendo DSi XL Touchscreen Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Nintendo DSi XL Touchscreen Replacement: Schritt 11, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 11, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Touchscreen Replacement: Schritt 12, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 12, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Touchscreen Replacement: Schritt 13, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 13, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Touchscreen Replacement: Schritt 14, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 14, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Nintendo DSi XL Touchscreen Replacement: Schritt 15, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 15, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Touchscreen Replacement: Schritt 16, Bild 1 von 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Nintendo DSi XL Touchscreen Replacement: Schritt 17, Bild 1 von 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Nintendo DSi XL Touchscreen Replacement: Schritt 18, Bild 1 von 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Touchscreen Replacement: Schritt 19, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 19, Bild 2 von 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Touchscreen Replacement: Schritt 20, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 20, Bild 2 von 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  21. Nintendo DSi XL Touchscreen Replacement, Lower Display Assembly: Schritt 21, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement, Lower Display Assembly: Schritt 21, Bild 2 von 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Nintendo DSi XL Touchscreen Replacement, Lower LCD: Schritt 22, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement, Lower LCD: Schritt 22, Bild 2 von 2
    • Insert a spudger between the touchscreen and top right corner of the display.
    • Slide the spudger down the right side of the display to free the edge of the touchscreen.
  23. Nintendo DSi XL Touchscreen Replacement: Schritt 23, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 23, Bild 2 von 2
    • Continue around the bottom right corner of the display with the spudger.
    • Slide the spudger along the bottom edge of the touchscreen to separate it from the display.
  24. Nintendo DSi XL Touchscreen Replacement: Schritt 24, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 24, Bild 2 von 2
    • Continue around the bottom left corner of the display with a spudger.
    • Slide the spudger along the left edge of the touchscreen to remove it from the display.
  25. Nintendo DSi XL Touchscreen Replacement: Schritt 25, Bild 1 von 2 Nintendo DSi XL Touchscreen Replacement: Schritt 25, Bild 2 von 2
    • With three sides freed, remove the touchscreen from the lower display.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.523 Reputation
127 Anleitungen geschrieben
3 Kommentare
Great tutorial, I completely missed the fact that the lower screen is TWO screens: the touchscreen and the proper screen. Nailed it!!
luissebastianangeles - Antwort
thankyou! <3
Zenn22 - Antwort
Step 16 = whole socket came off the motherboard with the least amount of effort. Tried soldering new contacts but too fine. Device now only good for parts.
Reese Banister - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 101
Letzte 30 Tage: 381
Insgesamt: 42,738
