Zum Hauptinhalt wechseln
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Was du brauchst
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: Schritt 1, Bild 1 von 1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 3, Bild 1 von 1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 4, Bild 1 von 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 4, Bild 2 von 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 4, Bild 3 von 3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 5, Bild 1 von 2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 5, Bild 2 von 2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 6, Bild 1 von 1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 7, Bild 1 von 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 7, Bild 2 von 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: Schritt 7, Bild 3 von 3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 78
Insgesamt: 2,651
