Zum Hauptinhalt wechseln
PSP 300x D-Pad Replacement
Was du brauchst
  1. PSP 300x D-Pad Replacement, Battery: Schritt 1, Bild 1 von 3 PSP 300x D-Pad Replacement, Battery: Schritt 1, Bild 2 von 3 PSP 300x D-Pad Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Casing: Schritt 2, Bild 1 von 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x D-Pad Replacement: Schritt 3, Bild 1 von 2 PSP 300x D-Pad Replacement: Schritt 3, Bild 2 von 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: Schritt 4, Bild 1 von 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: Schritt 5, Bild 1 von 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x D-Pad Replacement: Schritt 6, Bild 1 von 2 PSP 300x D-Pad Replacement: Schritt 6, Bild 2 von 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x D-Pad Replacement, D-Pad: Schritt 7, Bild 1 von 2 PSP 300x D-Pad Replacement, D-Pad: Schritt 7, Bild 2 von 2
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
mbnewsom
3.103 Reputation
11 Anleitungen geschrieben
Ein Kommentar
Is it for 2000?
Kaio Igor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 32
Letzte 30 Tage: 113
Insgesamt: 9,351
