Zum Hauptinhalt wechseln
PSP 300xc Power Jack Replacement
Was du brauchst
  1. PSP 300xc Power Jack Replacement, Battery: Schritt 1, Bild 1 von 2 PSP 300xc Power Jack Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
    Frag FixBot
    Kommentar hinzufügen
  2. PSP 300xc Power Jack Replacement, Front Case: Schritt 2, Bild 1 von 1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
    Frag FixBot
  3. PSP 300xc Power Jack Replacement: Schritt 3, Bild 1 von 2 PSP 300xc Power Jack Replacement: Schritt 3, Bild 2 von 2
    • Remove four Phillips screws from the back of the PSP.
    Frag FixBot
  4. PSP 300xc Power Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove two Phillips screws from the top of the PSP.
    Frag FixBot
  5. PSP 300xc Power Jack Replacement: Schritt 5, Bild 1 von 1
    • Remove a single screw from the bottom edge of the PSP.
    Frag FixBot
  6. PSP 300xc Power Jack Replacement: Schritt 6, Bild 1 von 2 PSP 300xc Power Jack Replacement: Schritt 6, Bild 2 von 2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
    Frag FixBot
  7. PSP 300xc Power Jack Replacement, LCD: Schritt 7, Bild 1 von 1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
    Frag FixBot
  8. PSP 300xc Power Jack Replacement: Schritt 8, Bild 1 von 2 PSP 300xc Power Jack Replacement: Schritt 8, Bild 2 von 2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
    Frag FixBot
  9. PSP 300xc Power Jack Replacement: Schritt 9, Bild 1 von 1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
    Frag FixBot
  10. PSP 300xc Power Jack Replacement: Schritt 10, Bild 1 von 1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
    Frag FixBot
  11. PSP 300xc Power Jack Replacement: Schritt 11, Bild 1 von 3 PSP 300xc Power Jack Replacement: Schritt 11, Bild 2 von 3 PSP 300xc Power Jack Replacement: Schritt 11, Bild 3 von 3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
    Frag FixBot
  12. PSP 300xc Power Jack Replacement: Schritt 12, Bild 1 von 1
    • Remove the LCD from the PSP 300xc.
    Frag FixBot
  13. PSP 300xc Power Jack Replacement, Home Bar: Schritt 13, Bild 1 von 3 PSP 300xc Power Jack Replacement, Home Bar: Schritt 13, Bild 2 von 3 PSP 300xc Power Jack Replacement, Home Bar: Schritt 13, Bild 3 von 3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
    Frag FixBot
  14. PSP 300xc Power Jack Replacement, Trigger Buttons: Schritt 14, Bild 1 von 2 PSP 300xc Power Jack Replacement, Trigger Buttons: Schritt 14, Bild 2 von 2
    • Remove both trigger buttons by lifting them off the PSP 300xc.
    Frag FixBot
  15. PSP 300xc Power Jack Replacement, Power Switch Board: Schritt 15, Bild 1 von 1
    • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
    • Pull the ribbon cable out of its socket.
    Frag FixBot
  16. PSP 300xc Power Jack Replacement: Schritt 16, Bild 1 von 1
    • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
    • Remove the power switch board from the PSP.
    Frag FixBot
  17. PSP 300xc Power Jack Replacement, Power Jack: Schritt 17, Bild 1 von 1
    • Remove a single Phillips screw securing the power jack to the PSP.
    Frag FixBot
  18. PSP 300xc Power Jack Replacement: Schritt 18, Bild 1 von 1
    • Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
    Frag FixBot
  19. PSP 300xc Power Jack Replacement: Schritt 19, Bild 1 von 1
    • Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 116
Insgesamt: 10,039
