Zum Hauptinhalt wechseln
PSP E1000 Battery Replacement
Was du brauchst
  1. PSP E1000 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 PSP E1000 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • To start the replacement flip the device over
  2. PSP E1000 Battery Replacement: Schritt 2, Bild 1 von 2 PSP E1000 Battery Replacement: Schritt 2, Bild 2 von 2
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Battery Replacement: Schritt 3, Bild 1 von 2 PSP E1000 Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Battery Replacement: Schritt 5, Bild 1 von 3 PSP E1000 Battery Replacement: Schritt 5, Bild 2 von 3 PSP E1000 Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling, it is useful to use a spudger to push the cable back in.
    • Congratulations you have replaced your PSP E1000's battery
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Caleb Pierce
1.121 Reputation
8 Anleitungen geschrieben
1 Kommentar zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 48
Letzte 30 Tage: 254
Insgesamt: 2,240
