Zum Hauptinhalt wechseln
PlayStation 3 Slim (CECH-300X) Fan system Replacement
Was du brauchst
Einführungsvideo
  1. PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: Schritt 1, Bild 1 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: Schritt 1, Bild 2 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: Schritt 1, Bild 3 von 3
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 2, Bild 1 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 2, Bild 2 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 2, Bild 3 von 3
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 3, Bild 1 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 3, Bild 2 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 3, Bild 3 von 3
    • Remove the four Phillips screws and lift the top shield.
  4. PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 4, Bild 1 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 4, Bild 2 von 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: Schritt 4, Bild 3 von 3
    • That's all.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.539 Anleitungen geschrieben
2 Kommentare
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - Antwort
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 64
Letzte 30 Tage: 247
Insgesamt: 16,533
