Einleitung
This guide explains the steps to replace your Samsung Chromebook 3 battery. You will start by turning your laptop upside down gently to remove the bottom case. Which is where your your battery is located.
Was du brauchst
Place the laptop back cover facing up to show the screws.
Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
