Zum Hauptinhalt wechseln
Samsung Chromebook Series 3 Charging Port Replacement
Was du brauchst
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 3, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 3, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 4, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 4, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: Schritt 5, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: Schritt 5, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: Schritt 5, Bild 3 von 3
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 6, Bild 1 von 2 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 7, Bild 1 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 7, Bild 2 von 3 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 7, Bild 3 von 3
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: Schritt 8, Bild 1 von 2 Samsung Chromebook Series 3 Charging Port Replacement: Schritt 8, Bild 2 von 2
    • You can now pull out the charging port module.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
UWT Liner: Group 1 Mitglied von UWT Liner: Group 1
Community
5 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Antwort
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 57
Insgesamt: 17,458
