Zum Hauptinhalt wechseln
Samsung Galaxy Media Player 5 Earpiece Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: Schritt 1, Bild 1 von 2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: Schritt 1, Bild 2 von 2
    • Remove the SD Memory Card before working on the device.
    • Use a Phillips screwdriver to remove the 10 mm screw near the SD Memory Card port.
  2. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 2, Bild 1 von 1
    • White caps cover screws on both sides of the charging port. Use the angled tweezers to remove them.
    • Use a blow dryer on low heat if necessary to loosen the adhesive.
  3. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips head screwdriver, unscrew the two 10 mm screws located on either side of the charging port.
  4. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 4, Bild 3 von 3
    • Using the opening pick, pry at the bottom and work around each edge of the device until the front cover and back cover housing is separated.
    • You will hear a popping sound to indicate the separation.
  5. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, apply an upward force to detach the battery and the tab attached to it.
  6. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: Schritt 6, Bild 3 von 3
    • Using the plastic opening tool, apply an upward force to detach the speaker earpiece.
    • Use the tweezers to attach the new earpiece speaker in place of the original.
    • Use a blow dryer, on low heat settings, to loosen the adhesive on the speaker earpiece.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
China Ayala
584 Reputation
4 Anleitungen geschrieben
Sam Houston State, Team 11-7, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-7, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 380
