Zum Hauptinhalt wechseln
Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement
Was du brauchst
  1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: Schritt 1, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $2.99
    Kaufen
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: Schritt 2, Bild 1 von 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: Schritt 2, Bild 2 von 2
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  3. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 1 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 2 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: Schritt 3, Bild 3 von 3
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  4. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: Schritt 4, Bild 3 von 3
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph Rasico
2.173 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Spring 2017 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 1,620
