Zum Hauptinhalt wechseln
Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: Schritt 1, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: Schritt 1, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: Schritt 1, Bild 3 von 3
    • Remove any SIM and SD card.
    • Remove 7x Phillips screws.
    • Use a plastic tool to disassemble the rear housing.
  2. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 2, Bild 1 von 1
    • The Loudspeaker is located on the rear housing..
  3. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: Schritt 3, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: Schritt 3, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: Schritt 3, Bild 3 von 3
    • Disconnect the LCD Display flex cable.
    • Lift up the board and disconnect the Touchscreen flex cable.
    • Now you can remove the Motherboard.
  4. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: Schritt 4, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: Schritt 4, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: Schritt 4, Bild 3 von 3
    • Warm the touchscreen to make separating the LCD Display more easy
    • For this manipulation you can use a hair drier.
    • In the four corners of LCD display there are small metal plates. Use one of them to lift a little the LCD and put the plastic tool.
    • Be careful not to break the display.
  5. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 5, Bild 3 von 3
    • After separating the LCD Display, again worm the Touchscreen.
    • If the glass is broken, put a transparent tape to prevent scattering.
  6. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 6, Bild 3 von 3
    • Use plastic tools and slowly separate the touch screen from the front bezel.
  7. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 7, Bild 3 von 3
    • If the new spare part has come without adhesive tape. you must put.
    • Reassemble your device, follow these instructions in reverse order.
  8. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: Schritt 8, Bild 1 von 1
    • Did you do it successfully?
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
ZFix
195.771 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
329 Mitglieder
1.451 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 7,714
