Zum Hauptinhalt wechseln
Samsung Galaxy S4 Mini Speaker Replacement
Was du brauchst
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: Schritt 3, Bild 1 von 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: Schritt 4, Bild 1 von 2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: Schritt 4, Bild 2 von 2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: Schritt 5, Bild 1 von 1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: Schritt 6, Bild 1 von 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: Schritt 6, Bild 2 von 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: Schritt 6, Bild 3 von 3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: Schritt 7, Bild 1 von 2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: Schritt 7, Bild 2 von 2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: Schritt 8, Bild 1 von 1
    • Insert the new loud speaker
Abschluss
31 weitere Nutzer:innen haben diese Anleitung absolviert.
Luis Ojeda
989 Reputation
1 Anleitung geschrieben
USF Tampa, Team 9-2, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Mitglieder
11 Anleitungen geschrieben
3 Kommentare
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Antwort
perfect. thankyou
rick bailey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 20
Insgesamt: 13,764
