Einleitung
This guide will show you how to replace the back facing camera on this device. This guide requires removal of the screen, buttons, battery and protective plate. This may mean that to replace this camera, other parts of the device must be replaced as well.
Was du brauchst
Remove the back casing of the phone using the notch located at the top.
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
Remove the back facing camera from the top of the phone by first disconnecting the ribbon cable from the connector with a spudger or tweezers.
