Zum Hauptinhalt wechseln
Samsung Galaxy S7 Austausch der Rückkameralinse
Was du brauchst
    • Folge dieser Anleitung, wenn du nur die Glaslinse über der Hauptkamera tauschen willst.
    • Wenn du du die ganze Blende austauschen willst dann überspringe diesen Schritt und fahre mit dem folgenden fort.
    • Folge diesem längeren Verfahren wenn du Blende und Linse auf der Gehäuserückseite tauschen willst.
    • Dazu benötigt du auch neue Klebestreifen für die Rückabdeckung. Beim Einkleben der Kamerablende und der Rückabdeckung hilft dir diese Anleitung.
Ziellinie
33 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Evan Noronha
223.490 Reputation
168 Anleitungen geschrieben
12 Kommentare
THANK YOU SO MUCH for the first video!!!
Grace Arnott - Antwort
Follow up... What happens if there is a bit of dust? Is there a way to get rid of it?
I ordered 2 lens replacements and neither one of the lenses have adhesive on either side do I need to buy some kind of adhesive sepratly or should 1 or these sides already have it on there
Joshua albano - Antwort
same thing with mine josh albano i just plopped it in and am going to hope for the best.
John Biello - Antwort
How can I make sure I don't get my replacement glass in backward.....because my focus is still gone. I'm devastated because I purchased this phone specifically for the camera to take pictures to upload to my eBay account. I worked for almost a full year before I could afford to buy this camera phone and I purchased it outright from straight talk. I own my camera and it is not insured. I followed your directions to replace my lens and now I'm worried I might have it in backward. How can I tell if the lens is in place incorrectly? By the way, my phone has never been dropped. It has been protected by an otter box since its purchase. My lens seemingly self-imploded. Just the strangest thing. Other than the lens, my camera doesn't have a scratch on it! Thank you for any help. Molly
Molly Azbell-Thompson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 36
Letzte 30 Tage: 102
Insgesamt: 152,877
