Zum Hauptinhalt wechseln
Samsung Galaxy Tab A 9.7 Headphone Jack Replacement
Was du brauchst
  1. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Remove one of the opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the strip from the motherboard with the iFixit opening tool.
  5. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 5, Bild 2 von 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  6. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 6, Bild 2 von 2
    • Remove both side pieces using one of the the iFixit opening tools.
    • Lift up the headphone jack port with the iFixit opening tool as well.
  7. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: Schritt 7, Bild 1 von 1
    • Pull up the headphone jack port carefully and replace.
Abschluss
To reassemble your device, follow the instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S1-G3, Hovde Spring 2019 Mitglied von IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 399
