Zum Hauptinhalt wechseln
Sony PlayStation 3D Display Control Buttons Replacement
Was du brauchst
  1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: Schritt 1, Bild 1 von 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Control Buttons Replacement: Schritt 2, Bild 1 von 3 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 2, Bild 2 von 3 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 2, Bild 3 von 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Control Buttons Replacement: Schritt 3, Bild 1 von 2 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 3, Bild 2 von 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Control Buttons Replacement: Schritt 4, Bild 1 von 3 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 4, Bild 2 von 3 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 4, Bild 3 von 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: Schritt 5, Bild 1 von 1
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
  6. Sony PlayStation 3D Display Control Buttons Replacement: Schritt 6, Bild 1 von 2 Sony PlayStation 3D Display Control Buttons Replacement: Schritt 6, Bild 2 von 2
    • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tia McNaughton
379 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-16, Maness Fall 2015 Mitglied von Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 530
