Zum Hauptinhalt wechseln
Surface Laptop Studio Headphone Jack Replacement
Was du brauchst
  1. Surface Laptop Studio Headphone Jack Replacement, Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Headphone Jack Replacement: Schritt 2, Bild 1 von 2 Surface Laptop Studio Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Headphone Jack Replacement: Schritt 5, Bild 1 von 2 Surface Laptop Studio Headphone Jack Replacement: Schritt 5, Bild 2 von 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: Schritt 6, Bild 1 von 2 Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: Schritt 6, Bild 2 von 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 1 von 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 2 von 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 3 von 3
    • Remove the left I/O bracket by unscrewing the the 3 M1109237 Screws with your T3 Torx screwdriver.
  8. Surface Laptop Studio Headphone Jack Replacement: Schritt 8, Bild 1 von 1
    • Remove the two M1168360 screws on the headphone jack with your T3 Torx screwdriver.
  9. Surface Laptop Studio Headphone Jack Replacement: Schritt 9, Bild 1 von 1
    • Flip up the headphone jack's ZIF connector locking flap.
    • Remove the ribbon cable from the port.
  10. Surface Laptop Studio Headphone Jack Replacement: Schritt 10, Bild 1 von 1
    Kaufen
    • Lift the headphone jack up and out with your tweezers.
Abschluss
Nate Ball
669 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 194
