Zum Hauptinhalt wechseln
Toshiba Satellite A660-ST3NX2X RAM Replacement
Was du brauchst
  1. Toshiba Satellite A660-ST3NX2X RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 2, Bild 2 von 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: Schritt 4, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: Schritt 4, Bild 2 von 2
    • Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
  5. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 5, Bild 1 von 1
    • Open the hatch that holds the RAM cards.
  6. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 6, Bild 2 von 2
    • Pull apart the two metal tabs that are holding the RAM cards in place.
    • You will feel the card pop up from its held position, indicating it can safely be pulled out.
  7. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 7, Bild 2 von 2
    • Pull out the top RAM card.
  8. Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: Schritt 8, Bild 2 von 2
    • Use tabs on the sides of the bottom RAM card to release the RAM card.
    • Remove the bottom RAM card, just as the top RAM card was removed.
Abschluss
Cassie Pickett
201 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S8-G1, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 18
Insgesamt: 376
