Zum Hauptinhalt wechseln
Toshiba Satellite A665-S5170 Battery Replacement
Was du brauchst
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A665-S5170 Battery Replacement: Schritt 3, Bild 3 von 3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team 4-5, Williams Fall 2016 Mitglied von Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 1,136
