Zum Hauptinhalt wechseln
Xbox One Optical Drive Laser Replacement
Was du brauchst
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: Schritt 1, Bild 1 von 1
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: Schritt 2, Bild 1 von 1
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: Schritt 3, Bild 1 von 2 Xbox One Optical Drive Laser Replacement, Optical Drive Case: Schritt 3, Bild 2 von 2
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: Schritt 4, Bild 1 von 2 Xbox One Optical Drive Laser Replacement, ZIF Connectors: Schritt 4, Bild 2 von 2
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: Schritt 5, Bild 1 von 1
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: Schritt 6, Bild 1 von 1
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: Schritt 7, Bild 1 von 1
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: Schritt 8, Bild 1 von 1
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 39
Letzte 30 Tage: 139
Insgesamt: 4,281
