Re-connecting fan ribbon cable
I am trying to install a new fan but the ribbon cable is so small and flexible, I can't insert it into the ZIF socket.
Any suggestions?
Thanks
Update (08/27/2018)
I tried to do this and ended up breaking the latch while trying to pull the ribbon cable through the opening. Not happy about the result, although I think I have found a work-around
Ist dies eine gute Frage?
1 Kommentar
Sorry to hear you have broken the latch.
You’ll need to get a new base connector and carefully snap it out and replace your broken latch unless you broke the connector body side in which case you’ll need to get some one with good micro soldering skills to replace the full connector.
Haven’t had any luck with work-arounds - Sorry
von Dan
