12.7 mm PATA Optical Bay PATA Hard Drive Enclosure
  • 12.7 mm PATA Optical Bay PATA Hard Drive Enclosure
24,99 $
24,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
You can now have two hard drives in your laptop or Mac Mini! By replacing your optical drive, you can install up to a 320 GB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Optical Bay is 12.7 mm tall. Accepts 2.5 inch PATA hard drives up to 9.5 mm in height.
Kompatibilität
Kompatibilität
  • G4 Titanium Onyx PowerBooks with combo drives
  • G4 Titanium DVI PowerBooks with combo drives
  • All G4 Aluminum PowerBooks
  • All iBook G4s
  • All PowerPC Mac minis
Installationsvideo
Kompatibilität
iBook G4 12" 1.33 GHz
iBook G4 12" 800 MHz-1.2 GHz
1 GHz
1.2 GHz
800 MHz
iBook G4 14" 1.42 GHz
iBook G4 14" 933 MHz-1.33 GHz
1 GHz (128 RAM)
1 GHZ (256 RAM)
1.2 GHz
1.33 GHz
933 MHz
Mac mini (PowerPC)
1.25 GHz
1.33 GHz
1.42 GHz
1.5 GHz
PowerBook G4 Aluminum 12" 1-1.5 GHz
1 GHz
1.33 GHz
1.5 GHz
PowerBook G4 Aluminum 12" 867 MHz
PowerBook G4 Aluminum 15" 1-1.5 GHz
1 GHz
1.25 GHz
1.33 GHz
1.5 GHz (BT 1.1)
PowerBook G4 Aluminum 15" 1.5-1.67 GHz
1.5 GHz (BT 2.0)
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 15" 1.67 GHz
(High-Res)
PowerBook G4 Aluminum 17" 1-1.67 GHz
1 GHz
1.33 GHz
1.5 GHz
1.67 GHz (Low-Res)
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res)
(High-Res)
PowerBook G4 Titanium DVI
1 GHz
667 MHz
800 MHz
867 MHz
PowerBook G4 Titanium Onyx
550 MHz
667 MHz
11 weitere Geräte zeigen
