2 TB 3.5" Hard Drive
  • 2 TB 3.5" Hard Drive
  • 2 TB 3.5" Hard Drive / New / Seagate / ST2000DM006
69,99 $
69,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Replace or upgrade the hard drive in your compatible iMac with this part.
Hinweis
To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Hinweis
Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models).
Kompatibilität
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
13 weitere Geräte zeigen
Reparatur-Geschichten
Mein Problem
My old 2009 iMac crashed and after a visit to apple could not fix my "obsolete" computer it looked like the hard drive died. Having photos and stuff on it I used the iFixit guide to remove the hard drive. When I used an external USB connector the hard drive started working and worked when I replace . . .
Mein Problem
The HD died
Meine Reparatur
For someone that has replaced Hard Drives on a Macbook Pro, this fix was pretty easy. The hardest part would be getting the screen off and on by yourself. It was a little cumbersome to try and not touch the LCD while detaching/reattaching the cables.
Mein Rat
Follow a youtube video if needed. Pa . . .
Mein Problem
Old hard drive would no longer boot up or mount
Meine Reparatur
Straightforward. Went exactly as the repair guide said it would
Mein Rat
If you follow the procedure from ifixit, you should have no issues
Mein Problem
Repair was pretty easy except for the fact that after everything was complete it turns out I also needed a " owc temperature sensor switch " replacing the oem hd require this cable which connects to the hard drive and temperature sensor ...if not connect the fan thinks the hard drive is failing and . . .
Mein Problem
Lost hard drive on computer. All tests diagnosed the hard drive as dead. Taking it to an Apple Dealer was out if the question. More to repair than the computer is worth.
Meine Reparatur
Repair was easy thanks to your easy to follow instructions as well as tools that can be purchased from your website. I have already . . .
Mein Problem
hard drive died
Meine Reparatur
Easy
Mein Rat
Plug and Play. time capsule recognized the new drive and immediately stared backing up all our MAC computers
Mein Problem
My machine was beginning to run slower and with Safari the petty beach ball was appearing a little too often before the web page would load. Then the screen pop panic appeared, all white with no possibility of booting to the desk top screen.
Meine Reparatur
With some online research I stumbled upon the IFIXIT site a . . .
Mein Problem
iOS could not find the start volume but with a copy on a external hard drive it works (very slow but it works)
Meine Reparatur
With the description from iFixit it takes me not 15 minutes to replace the hard disk
Mein Rat
Perfect description
Mein Problem
The 1TB hard drive crashed and I reformatted and restored it but then it crashed again about a day or two later.
Meine Reparatur
The hard drive replacement was a breeze. It took about 1hour and after formatting the new drive and loading OS X Yosemite all I had to do was restore my files from my backup USB drive. T . . .
Mein Problem
Easy to do and very inexpensive way to get computer working
Meine Reparatur
Very well for a novice at this type of repair.
Great instructions. Could have used info on material to use in replacing the heat sensor to the HD. I used a silicon paste, but wasn't sure this was the right answer. Seems to work fine.
Mein Rat
For . . .
Mehr anzeigen
